* | testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | testsuites/sptests/sp[a-f*]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
* | score: Add node to insert to Chain_Node_order | Sebastian Huber | 2021-11-23 | 1 | -1/+7 |
| | | | | | | This allows to use additional members of the nodes for comparision. Update #4534. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | score: _Chain_Insert_ordered_unprotected() | Sebastian Huber | 2017-11-06 | 1 | -7/+12 |
| | | | | | | Change the chain order relation to use a directly specified left hand side value. This is similar to _RBTree_Insert_inline() and helps the compiler to better optimize the code. | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | score: Add _Chain_Initialize_one() | Sebastian Huber | 2016-09-06 | 2 | -0/+24 |
* | score: Add debug support to chains | Sebastian Huber | 2016-07-22 | 1 | -4/+32 |
| | | | | | | | This helps to detect * double insert, append, prepend errors, and * get from empty chain errors. | ||||
* | score: Add Chain_Iterator | Sebastian Huber | 2016-04-18 | 3 | -2/+128 |
| | | | | | Add a chain iterator for safe iteration of chains with concurrent node extraction. | ||||
* | sapi: Add rtems_chain_get_first_unprotected() | Sebastian Huber | 2015-11-05 | 1 | -0/+7 |
| | | | | Close #2459. | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | sapi: Use one SMP lock for all chains | Sebastian Huber | 2014-03-11 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133. In order to support profiling of SMP locks and provide a future compatible SMP locks API it is necessary to add an SMP lock destroy function. Since the commit above adds an SMP lock to each chain control we would have to add a rtems_chain_destroy() function as well. This complicates the chain usage dramatically. Thus revert the patch above. A global SMP lock for all chains is used to implement the protected chain operations. Advantages: * The SAPI chain API is now identical on SMP and non-SMP configurations. * The size of the chain control is reduced and is then equal to the Score chains. * The protected chain operations work correctly on SMP. Disadvantage: * Applications using many different chains and the protected operations may notice lock contention. The chain control size drop is a huge benefit (SAPI chain controls are 66% larger than the Score chain controls). The only disadvantage is not really a problem since these applications can use specific interrupt locks and unprotected chain operations to avoid this issue. | ||||
* | sapi: SMP support for chains | Sebastian Huber | 2013-08-30 | 1 | -8/+20 |
| | | | | | | | | Add ISR lock to chain control for proper SMP protection. Replace rtems_chain_extract() with rtems_chain_explicit_extract() and rtems_chain_insert() with rtems_chain_explicit_insert() on SMP configurations. Use rtems_chain_explicit_extract() and rtems_chain_explicit_insert() to provide SMP support. | ||||
* | score: Add and use CHAIN_INITIALIZER_ONE_NODE(). | Sebastian Huber | 2013-08-27 | 1 | -0/+26 |
| | | | | | | Add and use CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(), RTEMS_CHAIN_INITIALIZER_ONE_NODE() and RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(). | ||||
* | score: Add _Chain_Insert_ordered_unprotected() | Sebastian Huber | 2013-06-14 | 3 | -0/+36 |
* | score: Add rtems_chain_node_count_unprotected() | Sebastian Huber | 2012-12-21 | 3 | -1/+23 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -1/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-11-26 Gedare Bloom <gedare@rtems.org> | Gedare Bloom | 2011-11-26 | 2 | -0/+22 |
| | | | | | | PR 1964 * spchain/init.c, spchain/spchain.scn: Add testcases for chain is first and last | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -5/+25 |
| | | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns. | ||||
* | 2011-03-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-03-09 | 1 | -0/+13 |
| | | | | * spchain/init.c: Improve coverage testing. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-11-26 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-26 | 1 | -0/+4 |
| | | | | * spchain/init.c: Added test case. | ||||
* | 2010-11-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-25 | 2 | -0/+22 |
| | | | | * spchain/init.c, spchain/spchain.scn: More test cases. | ||||
* | 2010-10-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-10-26 | 1 | -1/+14 |
| | | | | * spchain/init.c: Attempt to improve coverage. | ||||
* | 2010-10-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-10-25 | 1 | -1/+1 |
| | | | | * spchain/init.c, spwatchdog/task1.c: Do not violate chain API. | ||||
* | 2010-08-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-08-24 | 3 | -1/+109 |
| | | | | | * spchain/init.c, spchain/spchain.doc, spchain/spchain.scn: New test cases. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | 2009-07-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-08 | 1 | -1/+0 |
| | | | | | | | * sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded USE_TIMER_SERVER which was copied fomr other Makefile.am's. | ||||
* | 2009-07-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-02 | 2 | -23/+4 |
| | | | | * spchain/init.c, spchain/spchain.scn: Clean up test. | ||||
* | 2009-07-01 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-01 | 5 | -0/+149 |
* Makefile.am, configure.ac: Add new test to cover bodies of some chain routines whose bodies are not used by RTEMS itself. * spchain/.cvsignore, spchain/Makefile.am, spchain/init.c, spchain/spchain.doc, spchain/spchain.scn: New files. |
