Updates #3053.
Update #3533.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* sp09/screen12.c, sp09/sp09.scn, sp21/Makefile.am, sp35/priinv.c,
sp39/init.c, sp50/init.c, sp57/init.c, sp72/init.c, sp73/init.c,
spintrcritical01/init.c, spprivenv01/init.c, spsimplesched01/init.c,
spsimplesched02/init.c: Remove warnings.
* Makefile.am, configure.ac: Add sp73. This is a new test designed
to improve coverage of the thread yield logic.
* sp73/.cvsignore, sp73/Makefile.am, sp73/init.c, sp73/sp73.doc,
sp73/sp73.scn: New files.
