* | testsuites/sptests/sp0*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | testsuites: Remove rtems_test_pause*() | Sebastian Huber | 2019-12-04 | 1 | -2/+0 |
| | | | | | | | | | | | | | The rtems_test_pause() and rtems_test_pause_and_screen_number() macros had different implementations depending on the RTEMS_TEST_NO_PAUSE define. This define was defined to 1 by default. The user was able to change this via the undocumented --disable-test-no-pause configure command line option. Pausing tests and waiting for user input contradicts the goal of having automated test runs. Remove this feature. Update #3818. | ||||
* | tests: Use rtems_task_exit() | Sebastian Huber | 2018-10-05 | 1 | -2/+1 |
| | | | | Update #3533. | ||||
* | sptests/sp07: Fix test case | Sebastian Huber | 2016-01-04 | 1 | -8/+0 |
| | | | | | | Fix things broken by commit d5154d0f6a04f3b7ed59d9a09038576fe2640756. Update #2493. | ||||
* | api: Remove deprecated Notepads | Aun-Ali Zaidi | 2015-12-24 | 1 | -16/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | Notepads where a feature of RTEMS' tasks that simply functioned in the same way as POSIX keys or threaded local storage (TLS). They were introduced well before per task variables, which are also deprecated, and were barely used in favor of their POSIX alternatives. In addition to their scarce usage, Notepads took up unnecessary memory. For each task: - 16 32-bit integers were allocated. - A total of 64 bytes per task per thread. This is especially critical in low memory and safety-critical applications. They are also defined as uint32_t, and therefore are not guaranteed to hold a pointer. Lastly, they are not portable solutions for SMP and uniprocessor systems, like POSIX keys and TLS. updates #2493. | ||||
* | tm07: Split some code into new spnotepad02. | Joel Sherrill | 2015-03-17 | 1 | -0/+5 |
| | | | | | | Use of deprecated notepads in sp07 needs further work. Updates #2305. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -18/+15 |
| | | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Use PRIdrtems_task_priority to print rtems_task_priority's. | Ralf Corsepius | 2009-10-26 | 1 | -4/+4 |
* | 2007-12-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-12-20 | 1 | -2/+1 |
| | | | | | * sp07/task1.c, sp34/changepri.c, sp35/priinv.c: Add rtems_task_self() directive instead of violating RTEMS internals. | ||||
* | 2007-12-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-13 | 1 | -1/+5 |
| | | | | | | | * sp07/init.c, sp07/sp07.scn, sp07/task1.c: Add tests for using notepad with the current task's ID or SELF * sp09/screen02.c, sp09/screen04.c, sp09/sp09.scn: Add test missing test cases for clock_get. | ||||
* | 2007-11-27 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-11-27 | 1 | -1/+1 |
| | | | | | | | * sp07/sp07.scn, sp07/task1.c, sp09/screen01.c, sp09/screen05.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen14.c, sp09/sp09.scn, sp25/sp25.scn, sp25/task1.c: Added several test cases to improve test coverage. | ||||
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | The name of the test support routine pause was changed to rtems_test_pause | Joel Sherrill | 1996-02-22 | 1 | -1/+1 |
| | | | | to avoid conflict with the standard POSIX routine pause(2). | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+85 |
