brains GmbH.
Updates #3053.
Updates #4625.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3732.
Update #3533.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Update #2811.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
This is a preparation to remove the Giant lock.
Update #2555.
Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable().
Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable().
Update #2555.
Add _Thread_Change_life_locked() as a general function to alter the
thread life state. Use it to implement _Thread_Set_life_protection() as
a first step.
Update #2555.
Update #2626.
According to the C11 and C++11 memory models only a read-modify-write
operation guarantees that we read the last value written in modification
order. Avoid the sequential consistent thread fence and instead use the
inter-processor interrupt to set the thread dispatch necessary
indicator.
Close the thread object in _Thread_Make_zombie() so that all blocking
operations that use _Thread_Get() in the corresponding release directive
can find a terminating thread and can complete the operation.
Enable usage of _Thread_Set_life_protection() in thread dispatch
critical sections. This can be used to enable the thread
life-protection with thread dispatching disabled and then enable thread
dispatching.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
The thread restart is now supported on SMP. New test
smptests/smpthreadlife01.
