* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | testsuites/smptests/*: Change license to BSD-2 | Joel Sherrill | 2022-04-07 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 2020-07-23 | 1 | -1/+1 |
| | | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | ||||
* | config: Use new scheduler configuration defines | Sebastian Huber | 2018-03-12 | 1 | -4/+4 |
| | | | | Update #3325. | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | smptests: Split smpscheduler03 | Sebastian Huber | 2017-06-29 | 1 | -0/+59 |
Split smpscheduler03 to run the tests with only one processor. Update #3056. |
