brains GmbH.
Updates #3053.
Updates #4625.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
Update #3325.
Update #3170.
Update #3199.
Split smpscheduler03 to run the tests with only one processor.
Update #3056.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Initialize the thread queue context with invalid data in debug
configurations to catch missing set up steps.
Update #2556.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
Remove unused return status.
Changed for consistency with other scheduler operations.
Update #2556.
Update #2556.
Update #2556.
This enables to call this scheduler operation for all scheduler nodes
available to a thread.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Avoid direct access to thread internal data fields.
Task priorities are only valid within a scheduler instance. The
rtems_task_set_scheduler() directive moves a task from one scheduler
instance to another using the current priority of the thread. However,
the current task priority of the source scheduler instance is undefined
in the target scheduler instance. Add a third parameter to specify the
priority.
Close #2749.
The thread priority is manifest in two independent areas. One area is
the user visible thread priority along with a potential thread queue.
The other is the scheduler. Currently, a thread priority update via
_Thread_Change_priority() first updates the user visble thread priority
and the thread queue, then the scheduler is notified if necessary. The
priority is passed to the scheduler via a local variable. A generation
counter ensures that the scheduler discards out-of-date priorities.
This use of a local variable ties the update in these two areas close
together. For later enhancements and the OMIP locking protocol
implementation we need more flexibility. Add a thread priority
information block to Scheduler_Node and synchronize priority value
updates via a sequence lock on SMP configurations.
Update #2556.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Replace _Thread_Get() with _Thread_Get_interrupt_disable() to avoid the
Giant lock.
Update #2555.
In addition protect scheduler of thread by thread state lock. Enables
use of scheduler per-instance locks.
Update #2555.
Restructure to avoid large maximum thread dispatch disabled times.
Move the writes to Thread_Control::current_priority and
Thread_Control::real_priority into _Thread_Change_priority() under the
protection of the thread lock. Add a filter function to
_Thread_Change_priority() to enable specialized variants.
Avoid race conditions during a thread priority restore with the new
Thread_Control::priority_restore_hint for an important average case
optimizations used by priority inheritance mutexes.
Update #2273.
Return a thread in need for help for the following scheduler operations
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
Extract code from _Scheduler_SMP_Enqueue_ordered() and move it to the
new function _Scheduler_SMP_Enqueue_scheduled_ordered() to avoid
untestable execution paths.
Add and use function _Scheduler_SMP_Unblock().
