This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Updates #3053.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
This define represents the last valid interrupt vector number.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
Update #3732.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
This patches some issues with the capture engine:
1. Check is the engine is open in ctrace commands.
2. Check all record open and appends for overflow.
3. Fix the record open to take the size of user data and
not the record header.
4. Use packed structs for data being written to the per
cpu buffers.
5. Remove direct struct access to the capture buffers to
avoid misaligned accesses.
6. Add support to extract records, no struct access to the
capture buffers.
7. Update ctrace to extract records from the capture buffers.
8. Add support to ctrace to always print the task name if it
has one.
9. Add support to manage names or the lack of a name.
10. Range of minor fixes.
11. Fix a long standing bug in ctset's handling of args.
Closes #2780.
Fix overall clock tick count. Change introduced by
90d8567d34a6d80da04b1cb37b667a3173f584c4.
Update #2554.
