* sample.am: Set project_bspdir=$(PROJECT_ROOT)
* sample.am: Remove LIB_VARIANT.
* samples.am: Fix yet another stupid typo in yesterday's patch.
* samples.am: Add dirstamp support.
* sample.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* minimum/Makefile.am: Fix comments to make automake-1.5 happy.
* sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* cdtest/Makefile.am: Remove LD_LIBS.
* sample.am: Remove DEFS.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
<corsepiu@faw.uni-ulm.de>.
