* | testsuites: Remove all legacy networking tests | Vijay Kumar Banerjee | 2021-04-07 | 1 | -11/+0 |
| | | | | Update #3850 | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
* | 2003-04-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-04-29 | 1 | -0/+15 |
Adding pppd: * pppd/Makefile-user: New, copied over from libnetworking/pppd/example. * pppd/README: New, copied over from libnetworking/pppd/example. * pppd/init.c: New, copied over from libnetworking/pppd/example. * pppd/netconfig.h: New, copied over from libnetworking/pppd/example. * pppd/ppp.conf: New, copied over from libnetworking/pppd/example. * pppd/pppdapp.c: New, copied over from libnetworking/pppd/example. * pppd/system.h: New, copied over from libnetworking/pppd/example. * pppd/pppd.options: New, copied over from libnetworking/pppd/example. * pppd/Makefile.am: New, converted to automake from Makefile-user. * pppd/.cvsignore: New. |
