Updates #3053.
Update #3533.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
call to printk.
Updates #3170.
of this patch set.
* capture/init.c: Declare notification only if being used.
* fileio/fileio.scn: New file.
* capture/init.c, fileio/init.c: Use rtems_shell_wait_for_input().
* capture/init.c, capture/system.h, capture/test1.c: Removed CRs
from files. Committed incorrectly.
* Makefile.am, README, configure.ac, capture/.cvsignore,
capture/Makefile.am, capture/capture.doc, capture/capture.scn,
capture/init.c, capture/system.h, capture/test1.c: Add a sample
test for the capture engine.
