* | psxtmtests/*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-06-14 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2011-08-04 Ricardo Aguirre <el.mastin@ymail.com> | Joel Sherrill | 2011-08-04 | 1 | -0/+14 |
PR 1887/tests * Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of pthread_rwlock_unlock - thread waiting, no preempt. * psxtmrwlock06/.cvsignore, psxtmrwlock06/Makefile.am, psxtmrwlock06/init.c, psxtmrwlock06/psxtmrwlock06.doc: New files. |
