brains GmbH.
Updates #3053.
Updates #4625.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
