Updates #3053.
GCC originally needed this 20 years ago. No longer needed, so it
is being removed.
Closes #4391
Update #3732.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Change sysconf(0x12345678) check into sysconf(INT_MAX) for better
16bit compliance.
* psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add test for
getpagesize().
* psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add missing error test
case to improve coverage analysis.
* Makefile.am, configure.ac: Add test for sysconf().
* psxsysconf/.cvsignore, psxsysconf/Makefile.am, psxsysconf/init.c,
psxsysconf/psxsysconf.scn, psxsysconf/system.h: New files.
