path: root/testsuites/psxtests/psxstrsignal01 (follow)
* testsuites/psxtests/psx[n-z]*: Change license to BSD-2Joel Sherrill2022-04-122-6/+44
| | | | Updates #3053.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-24/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* psxstrsignal01: Remove warningsJoel Sherrill2017-04-041-0/+4
* psxstrsignal01: New testJoel Sherrill2017-03-154-0/+196
