* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 1 | -1/+0 |
| | | | | | | * psxreaddir/psxreaddir.scn, psxreaddir/test.c: Do not test for rewinddir(NULL) since we are now using newlib's implementation and it does not check for NULL. This causes a fault on some targets. | ||||
* | 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> | Jennifer Averett | 2000-11-17 | 1 | -78/+89 |
| | | | | | | | | * psxmount/test.c, psxmount/psxmount.scn: Improve output to report expected error condition in one case. * psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise readdir() of root of mounted filesystem. Also corrected the screen file for some mistakes noticed in this effort. | ||||
* | Modified file to match seen output. | Jennifer Averett | 1999-11-16 | 1 | -92/+161 |
* | Removed all ^M from the file. | Jennifer Averett | 1998-12-03 | 1 | -156/+156 |
* | Added tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 1 | -0/+156 |
