path: root/testsuites/psxtests/psxkey02 (follow)
* testsuites/psxtests/psx[g-m1]*: Change license to BSD-2Joel Sherrill2022-04-122-6/+44
| | | | Updates #3053.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-23/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* posix: Delete key/value if value is set to NULLSebastian Huber2014-12-121-0/+19
* psxtests/psxkey02: Test for proper error caseSebastian Huber2014-04-072-37/+14
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* POSIX keys now enabled in all configurations.Joel Sherrill2014-03-072-8/+8
| | | | | | | Formerly POSIX keys were only enabled when POSIX threads were enabled. Because they are a truly safe alternative to per-task variables in an SMP system, they are being enabled in all configurations.
* psxtests/psxkey02: SimplifySebastian Huber2013-06-252-71/+23
| | | | This avoids problems with debugging enabled.
* psxtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-1/+4
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-10-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-211-13/+13
| | | | | | | | | | | | | | | | | | * psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate double space after parenthesis on rtems_test_assert().
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally committed patch.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c, psxfile02/psxfile02.doc, psxfile02/psxfile02.scn, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater than number of file descriptors configured.
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-081-13/+13
| | | | | | | | | | | | | | | | | | | | | | | * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* Whitespace removal.Ralf Corsepius2009-11-301-3/+3
* 2009-07-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-305-0/+199
* Makefile.am, configure.ac: Add new test for exercising running out of memory while allocating the key pointers. * psxkey02/.cvsignore, psxkey02/Makefile.am, psxkey02/init.c, psxkey02/psxkey02.doc, psxkey02/psxkey02.scn: New files.
