* | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 2020-07-23 | 1 | -1/+1 |
| | | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. | ||||
* | Tests for inttype.h methods | Eshan dhawan | 2020-04-07 | 1 | -1/+23 |
* | psxinttypes01: Remove invalid test cases | Sebastian Huber | 2019-11-26 | 1 | -20/+0 |
| | | | | | | The functions expect a valid string as input according to POSIX. On systems with a NULL pointer protection the test cases ended up in exceptions. | ||||
* | psxtests: Add psxinttypes01 for <inttypes.h> methods | Vaibhav Gupta | 2019-06-19 | 1 | -0/+233 |
