path: root/testsuites/psxtests/psxhdrs/pthread31.c (follow)
* psxhdrs: Reorganize into subdirectories per .h file and rename filesJoel Sherrill2015-02-121-33/+0
| | | | | This is a better organization and makes it clearer which file is testing which method from which header file.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-101-1/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c, psxhdrs/timer07.c: Fix warnings.
* Remove stray white spaces.Ralf Corsepius2004-04-161-1/+1
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c, psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h, psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c, psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h, psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h, psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c, psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c, psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c, psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c, psxtimer/system.h: URL for license changed.
* Fixed comment block at the beginning of the file for a copyright dateJoel Sherrill1998-06-091-2/+2
| | | | problem and an English problem.
* new filesJoel Sherrill1996-05-231-0/+29
