path: root/testsuites/psxtests/psxfile01 (follow)
* testsuites/psxtests/psx[a-f]*: Change license to BSD-2Joel Sherrill2022-04-125-15/+110
| | | | Updates #3053.
* config: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORSSebastian Huber2019-12-191-1/+1
| | | | | | | Rename CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS into CONFIGURE_MAXIMUM_FILE_DESCRIPTORS. Update #3753.
* psxfile01: Fix one second sleepJiri Gaisler2019-01-071-1/+1
| | | | | | | | Checking of atime in psxfile01 (line 713) can fail since a delay for rtems_clock_get_ticks_per_second (line 699) gives a delay of less than one second, depending on when the last tick occurred. atime is measured in whole seconds, and a fast processor might read the file before a new second occurs. Add one tick to the delay will solve the problem.
* Support O_NOFOLLOW open() flagSebastian Huber2018-10-221-0/+67
| | | | Close #3546.
* Support O_CLOEXEC open() flagSebastian Huber2018-10-221-4/+28
| | | | | | Make sure this flag is ignored and does not prevent a successful open. Close #3547.
* Support O_DIRECTORY open() flagSebastian Huber2018-10-181-0/+25
| | | | Close #3545.
* psxfile01: floating point context required when calling fprintfDaniel Hellstrom2018-08-241-0/+2
| | | | | This avoids an exception (FP disabled) when RTEMS/Newlib have been built with LLVM/Sparc.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-20/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* psxfile01: Use floating-point taskSebastian Huber2018-01-191-0/+1
| | | | This test uses fprintf().
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-232-6/+6
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* termios: Use IMFS nodes for new Termios devicesSebastian Huber2016-09-191-1/+2
| | | | | | | | This makes the new Termios devices independent of device major/minor numbers. It enables BSP independent Termios device drivers which may reside in the cpukit domain. These drivers require an IMFS and do not work with the device file system. However, the device file system should go away in the future.
* IMFS: Add fine grained configurationSebastian Huber2015-02-121-0/+2
| | | | | | | | | | | | | | | | | | Remove miniIMFS. Statically initialize the root IMFS. Add configuration options to disable individual features of the root IMFS, e.g. o CONFIGURE_IMFS_DISABLE_CHOWN, o CONFIGURE_IMFS_DISABLE_FCHMOD, o CONFIGURE_IMFS_DISABLE_LINK, o CONFIGURE_IMFS_DISABLE_MKNOD, o CONFIGURE_IMFS_DISABLE_MOUNT, o CONFIGURE_IMFS_DISABLE_READLINK, o CONFIGURE_IMFS_DISABLE_RENAME, o CONFIGURE_IMFS_DISABLE_RMNOD, o CONFIGURE_IMFS_DISABLE_SYMLINK, o CONFIGURE_IMFS_DISABLE_UNMOUNT, and o CONFIGURE_IMFS_DISABLE_UTIME.
* IMFS: Replace node union with individual structSebastian Huber2015-01-272-83/+6
| | | | | | This reduces the average node size. Add and use IMFS_GENERIC_INITIALIZER().
* Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEMSebastian Huber2014-12-161-1/+0
| | | | This define was superfluous, undocumented and used inconsistently.
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-252-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-215-5/+5
* psxtests/psxfile01: Fix according to POSIXSebastian Huber2013-09-131-4/+4
| | | | | | | | | | | | | | | | | ftruncate() and open() with O_TRUNC shall upon successful completion mark for update the st_ctime and st_mtime fields of the file. truncate() shall upon successful completion, if the file size is changed, mark for update the st_ctime and st_mtime fields of the file. The POSIX standard "The Open Group Base Specifications Issue 7", IEEE Std 1003.1, 2013 Edition says nothing about the behaviour of truncate() if the file size remains unchanged. Future directions of the standard may mandate the behaviour specified in ftruncate(): http://austingroupbugs.net/view.php?id=489
* testsuites: Fix warningsSebastian Huber2013-04-112-22/+37
* Filesystem: Use ioctl_command_tSebastian Huber2012-05-151-3/+1
* psxtests - Eliminate missing prototype warningsJoel Sherrill2012-05-115-19/+45
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-116-15/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Filesystem: Reference counting for locationsSebastian Huber2012-03-132-10/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability.
* Apply missing patch.Ralf Corsepius2011-10-251-2/+0
* 2011-10-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-221-1/+0
| | | | * psxfile01/test.c: Remove local redeclaration of IMFS_dump.
* 2011-10-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-131-1/+3
| | | | | | * configure.ac: Check for size of mode_t. * psxfile01/test.c, psxstat/test.c: Include "primode.h". Use PRIomode_t to print mode_t.
* 2011-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-222-16/+16
| | | | | | PR 1839/filesystem * psxfchx01/init.c, psxfchx01/psxfchx01.scn, psxfile01/psxfile01.scn, psxfile01/test.c: Update test to reflect new status codes.
* 2011-05-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-061-1/+1
| | | | | * psxfile01/test.c, psxmsgq01/init.c, psxreaddir/test.c: Fix tests broken in warning pass.
* 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-051-1/+3
| | | | | | * psx04/task3.c, psxfile01/test.c, psxhdrs/Makefile.am, psxmsgq01/init.c, psxreaddir/test.c, psxsignal01/init.c, psxtimes01/init.c, psxualarm/init.c: Remove warnings.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-225-0/+20
* 2010-08-06 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-072-6/+10
| | | | | | | | | | | | | | PR 1654/testing * psx13/test.c, psx13/psx13.scn: Test case to improve testing of dup2 routine. * psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve testing of fcntl routine. * psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of imfs routines. * psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of imfs routines. * psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to improve coverage of getpwent.c.
* 2010-07-19 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-192-9/+85
| | | | | | | | | | | PR 1623/testing * psx13/test.c, psx13/psx13.scn: New cases to improve coverage of utime() and fpathconf(). * psxfile01/test.c, psxfile01/psxfile01.scn: New cases to improve coverage of rmdir(), unlink(), mknod(), link(), open(), read(), write(). * psxstat/test.c, psxstat/psxstat.scn: New case to improve coverage of readlink().
* 2010-07-16 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Sebastian Huber2010-07-161-3/+3
| | | | * psxfile01/test.c: Avoid NULL pointer access.
* 2010-07-15 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-152-2/+10
| | | | | | | | | | PR 1617/testing * psxfile01/test.c, psxfile01/psxfile01.scn: Added new cases to exercise_link_r and _unlink_r * psxstat/test.c, psxstat/psxstat.scn: Added new cases to exercise _lstat_r and _stat_r. * psxtime/test.c, psxtime/psxtime.scn: Added new cases to exercise _gettimeofday.
* 2010-07-08 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-082-9/+16
| | | | | | PR 1608/testing * psxfile01/init.c: Add a simple test case: Open file as read-only and attemp to truncate. Improves coverage.
* 2010-07-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-021-1/+1
| | | | * psxfile01/test_cat.c: Does not need posix specific macros.
* 2010-07-01 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-013-131/+20
| | | | | * psxfile01/Makefile.am, psxfile01/psxfile01.scn, psxfile01/test.c: Remove tests which put NULL entries in file handlers.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally committed patch.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c, psxfile02/psxfile02.doc, psxfile02/psxfile02.scn, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater than number of file descriptors configured.
* 2010-06-08 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Sebastian Huber2010-06-081-2/+4
| | | | * psxfile01/test.c: Update for IMFS API changes.
* 2010-06-02 Chris Johns <chrisj@rtems.org>Chris Johns2010-06-021-18/+18
| | | | | * psxfile01/test.c, psxmount/test.c, psxreaddir/test.c, psxstat/test.c: Update to the new mount API.
* 2010-05-17 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-05-172-23/+236
| | | | | | | * psxfile01/test.c, psxfile01/psxfile01.scn: This file now exercises the _rename_r in libcsupport. For now, it also provides two fsmount_me_h handlers to enable certain error checking paths
* 2010-04-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-04-281-1/+2
| | | | * psxfile01/test.c: Add check for errno on chdir(NULL).
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-084-76/+91
| | | | | | | | | | | | | | | | | | | | | | | * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* 2009-01-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-011-7/+3
| | | | | * psxfile01/test.c: Remove obsure #ifdef's. Apply PRI* macros to print struct stat fields.
