Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
* Makefile.am, configure.ac: Add test of pthread mutex auto
intialization.
* psxautoinit01/.cvsignore, psxautoinit01/Makefile.am,
psxautoinit01/init.c, psxautoinit01/psxautoinit01.scn: New files.
