Updates #3053.
This configuration option is obsolete since 2014.
Update #1367.
Update #3753.
Update #3170.
Update #3199.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
The file header was moved over one space. These two were the only
files in the testsuite which did this.
* psxaio01/system.h, psxaio02/system.h, psxaio03/system.h: Do not use
the stack checker.
* psxaio02/init.c: Improve aio_cancel() coverage.
* Makefile.am, configure.ac: Add psxaio01/, psxaio02/.
* psxaio01/Makefile.am, psxaio01/init.c, psxaio01/psxaio01.scn,
psxaio01/system.h: New.
* psxaio02/Makefile.am, psxaio02/init.c, psxaio02/psxaio02.scn,
psxaio02/system.h: New.
