Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* psx16/init.c, psxclassic01/init.c, psxeintr_join/init.c:
Add HAVE_CONFIG_H.
* psx16/.cvsignore, psx16/init.c, psx16/psx16.doc, psx16/psx16.scn: New
files. Accidentally missed in previous commit.
