* | testsuites/mptests/*: Change license to BSD-2. | Joel Sherrill | 2022-04-07 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | rtems: Add and use rtems_object_get_local_node() | Sebastian Huber | 2019-12-13 | 1 | -3/+1 |
| | | | | Update #3841. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-03 | 1 | -3/+3 |
| | | | | | | | * mp05/system.h, mp05/task1.c, mp06/system.h, mp06/task1.c, mp07/system.h, mp07/task1.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h: Convert to bool type. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 1 | -2/+2 |
| | | | | | | | | | | * mp02/task1.c, mp03/system.h, mp03/task1.c, mp04/task1.c, mp05/system.h, mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/task1.c, mp11/init.c, mp12/init.c, mp13/task1.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h: Convert to using c99 fixed size types. | ||||
| | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/init.c, mp01/system.h, mp01/task1.c, mp01/node1/mp01.doc, mp01/node2/mp01.doc, mp02/init.c, mp02/system.h, mp02/task1.c, mp02/node1/mp02.doc, mp02/node2/mp02.doc, mp03/delay.c, mp03/init.c, mp03/system.h, mp03/task1.c, mp03/node1/mp03.doc, mp03/node2/mp03.doc, mp04/init.c, mp04/system.h, mp04/task1.c, mp04/node1/mp04.doc, mp04/node2/mp04.doc, mp05/asr.c, mp05/init.c, mp05/system.h, mp05/task1.c, mp05/node1/mp05.doc, mp05/node2/mp05.doc, mp06/init.c, mp06/system.h, mp06/task1.c, mp06/node1/mp06.doc, mp06/node2/mp06.doc, mp07/init.c, mp07/system.h, mp07/task1.c, mp07/node1/mp07.doc, mp07/node2/mp07.doc, mp08/init.c, mp08/system.h, mp08/task1.c, mp08/node1/mp08.doc, mp08/node2/mp08.doc, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/system.h, mp09/task1.c, mp09/node1/mp09.doc, mp09/node2/mp09.doc, mp10/init.c, mp10/system.h, mp10/task1.c, mp10/task2.c, mp10/task3.c, mp10/node1/mp10.doc, mp10/node2/mp10.doc, mp11/init.c, mp11/system.h, mp11/node1/mp11.doc, mp11/node2/mp11.doc, mp12/init.c, mp12/system.h, mp12/node1/mp12.doc, mp12/node2/mp12.doc, mp13/init.c, mp13/system.h, mp13/task1.c, mp13/task2.c, mp13/node1/mp13.doc, mp13/node2/mp13.doc, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h, mp14/node1/mp14.doc, mp14/node2/mp14.doc: URL for license changed. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Modifications from Tony Bennett accepted to tune this test a little. | Joel Sherrill | 1995-09-19 | 1 | -4/+10 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+65 |
