path: root/testsuites/mptests/mp09/sendmsg.c (follow)
* testsuites/mptests/*: Change license to BSD-2.Joel Sherrill2022-04-071-3/+22
| | | | Updates #3053.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-121-4/+4
| | | | | | | | | * mp01/task1.c, mp02/task1.c, mp03/task1.c, mp05/task1.c, mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/init.c, mp12/init.c, mp13/init.c, mp13/task1.c, mp13/task2.c, mp14/evtask1.c, mp14/init.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second().
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-301-1/+1
| | | | | | | | | | * mp02/task1.c, mp03/system.h, mp03/task1.c, mp04/task1.c, mp05/system.h, mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/task1.c, mp11/init.c, mp12/init.c, mp13/task1.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h: Convert to using c99 fixed size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | * mp01/init.c, mp01/system.h, mp01/task1.c, mp01/node1/mp01.doc, mp01/node2/mp01.doc, mp02/init.c, mp02/system.h, mp02/task1.c, mp02/node1/mp02.doc, mp02/node2/mp02.doc, mp03/delay.c, mp03/init.c, mp03/system.h, mp03/task1.c, mp03/node1/mp03.doc, mp03/node2/mp03.doc, mp04/init.c, mp04/system.h, mp04/task1.c, mp04/node1/mp04.doc, mp04/node2/mp04.doc, mp05/asr.c, mp05/init.c, mp05/system.h, mp05/task1.c, mp05/node1/mp05.doc, mp05/node2/mp05.doc, mp06/init.c, mp06/system.h, mp06/task1.c, mp06/node1/mp06.doc, mp06/node2/mp06.doc, mp07/init.c, mp07/system.h, mp07/task1.c, mp07/node1/mp07.doc, mp07/node2/mp07.doc, mp08/init.c, mp08/system.h, mp08/task1.c, mp08/node1/mp08.doc, mp08/node2/mp08.doc, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/system.h, mp09/task1.c, mp09/node1/mp09.doc, mp09/node2/mp09.doc, mp10/init.c, mp10/system.h, mp10/task1.c, mp10/task2.c, mp10/task3.c, mp10/node1/mp10.doc, mp10/node2/mp10.doc, mp11/init.c, mp11/system.h, mp11/node1/mp11.doc, mp11/node2/mp11.doc, mp12/init.c, mp12/system.h, mp12/node1/mp12.doc, mp12/node2/mp12.doc, mp13/init.c, mp13/system.h, mp13/task1.c, mp13/task2.c, mp13/node1/mp13.doc, mp13/node2/mp13.doc, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h, mp14/node1/mp14.doc, mp14/node2/mp14.doc: URL for license changed.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+4
* Initial revisionJoel Sherrill1995-05-111-0/+59
