path: root/testsuites/mptests/mp04/node2/Makefile.am (follow)
* testsuite/mptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* mptests - Makefile.am did not set LINK_OBJSJoel Sherrill2012-05-041-1/+1
| | | | | | | | LINK_OBJS = instead of LINK_OBJS = $(mp01_node1_OBJECTS)
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-5/+1
| | | | | | | | | | | | | | | | | | | PR 1589/build * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove obsolete optional manager capability.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-01-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-301-1/+1
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-4/+2
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-12/+9
* Rework.Ralf Corsepius2005-11-111-34/+8
* Cosmetics.Ralf Corsepius2005-11-111-3/+0
* Various cleanups.Ralf Corsepius2005-11-111-4/+3
* Hard-code node number.Ralf Corsepius2005-11-111-11/+10
* Fix typo in previous patch.Ralf Corsepius2005-11-111-2/+2
* Eliminate TEST.Ralf Corsepius2005-11-111-7/+6
* Expand mptests.am.Ralf Corsepius2005-11-111-1/+22
* Eliminate DOCTYPES.Ralf Corsepius2005-11-101-2/+1
* Reflect changes to TEST variable contents.Ralf Corsepius2005-11-101-2/+2
* AM_CPPFLAGS += -I..../support/include.Ralf Corsepius2005-11-091-0/+2
* Misc. bugfixes.Ralf Corsepius2005-11-071-1/+1
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-10/+5
* 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-061-1/+1
| | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove $(LIB_VARIANT).
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * mp01/node2/Makefile.am: Ditto. * mp02/node1/Makefile.am: Ditto. * mp02/node2/Makefile.am: Ditto. * mp03/node1/Makefile.am: Ditto. * mp03/node2/Makefile.am: Ditto. * mp04/node1/Makefile.am: Ditto. * mp04/node2/Makefile.am: Ditto. * mp05/node1/Makefile.am: Ditto. * mp05/node2/Makefile.am: Ditto. * mp06/node1/Makefile.am: Ditto. * mp06/node2/Makefile.am: Ditto. * mp07/node1/Makefile.am: Ditto. * mp07/node2/Makefile.am: Ditto. * mp08/node1/Makefile.am: Ditto. * mp08/node2/Makefile.am: Ditto. * mp09/node1/Makefile.am: Ditto. * mp09/node2/Makefile.am: Ditto. * mp10/node1/Makefile.am: Ditto. * mp10/node2/Makefile.am: Ditto. * mp11/node1/Makefile.am: Ditto. * mp11/node2/Makefile.am: Ditto. * mp12/node1/Makefile.am: Ditto. * mp12/node2/Makefile.am: Ditto. * mp13/node1/Makefile.am: Ditto. * mp13/node2/Makefile.am: Ditto. * mp14/node1/Makefile.am: Ditto. * mp14/node2/Makefile.am: Ditto.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-181-4/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests.am: Add dirstamp support. * mptests/mp01/node1/Makefile.am: Eliminate VPATH. * mptests/mp01/node2/Makefile.am: Eliminate VPATH. * mptests/mp02/node1/Makefile.am: Eliminate VPATH. * mptests/mp02/node2/Makefile.am: Eliminate VPATH. * mptests/mp03/node1/Makefile.am: Eliminate VPATH. * mptests/mp03/node2/Makefile.am: Eliminate VPATH. * mptests/mp04/node1/Makefile.am: Eliminate VPATH. * mptests/mp04/node2/Makefile.am: Eliminate VPATH. * mptests/mp05/node1/Makefile.am: Eliminate VPATH. * mptests/mp05/node2/Makefile.am: Eliminate VPATH. * mptests/mp06/node1/Makefile.am: Eliminate VPATH. * mptests/mp06/node2/Makefile.am: Eliminate VPATH. * mptests/mp07/node1/Makefile.am: Eliminate VPATH. * mptests/mp07/node2/Makefile.am: Eliminate VPATH. * mptests/mp08/node1/Makefile.am: Eliminate VPATH. * mptests/mp08/node2/Makefile.am: Eliminate VPATH. * mptests/mp09/node1/Makefile.am: Eliminate VPATH. * mptests/mp09/node2/Makefile.am: Eliminate VPATH. * mptests/mp10/node1/Makefile.am: Eliminate VPATH. * mptests/mp10/node2/Makefile.am: Eliminate VPATH. * mptests/mp11/node1/Makefile.am: Eliminate VPATH. * mptests/mp11/node2/Makefile.am: Eliminate VPATH. * mptests/mp12/node1/Makefile.am: Eliminate VPATH. * mptests/mp12/node2/Makefile.am: Eliminate VPATH. * mptests/mp13/node1/Makefile.am: Eliminate VPATH. * mptests/mp13/node2/Makefile.am: Eliminate VPATH. * mptests/mp14/node1/Makefile.am: Eliminate VPATH. * mptests/mp14/node2/Makefile.am: Eliminate VPATH.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/Makefile.am: Reformat. * mp01/node1/Makefile.am: Remove all-local: $(ARCH). * mp01/node2/Makefile.am: Remove all-local: $(ARCH). * mp02/Makefile.am: Reformat. * mp02/node1/Makefile.am: Remove all-local: $(ARCH). * mp02/node2/Makefile.am: Remove all-local: $(ARCH). * mp03/Makefile.am: Reformat. * mp03/node1/Makefile.am: Remove all-local: $(ARCH). * mp03/node2/Makefile.am: Remove all-local: $(ARCH). * mp04/Makefile.am: Reformat. * mp04/node1/Makefile.am: Remove all-local: $(ARCH). * mp04/node2/Makefile.am: Remove all-local: $(ARCH). * mp05/Makefile.am: Reformat. * mp05/node1/Makefile.am: Remove all-local: $(ARCH). * mp05/node2/Makefile.am: Remove all-local: $(ARCH). * mp06/Makefile.am: Reformat. * mp06/node1/Makefile.am: Remove all-local: $(ARCH). * mp06/node2/Makefile.am: Remove all-local: $(ARCH). * mp07/Makefile.am: Reformat. * mp07/node1/Makefile.am: Remove all-local: $(ARCH). * mp07/node2/Makefile.am: Remove all-local: $(ARCH). * mp08/Makefile.am: Reformat. * mp08/node1/Makefile.am: Remove all-local: $(ARCH). * mp08/node2/Makefile.am: Remove all-local: $(ARCH). * mp09/Makefile.am: Reformat. * mp09/node1/Makefile.am: Remove all-local: $(ARCH). * mp09/node2/Makefile.am: Remove all-local: $(ARCH). * mp10/Makefile.am: Reformat. * mp10/node1/Makefile.am: Remove all-local: $(ARCH). * mp10/node2/Makefile.am: Remove all-local: $(ARCH). * mp11/Makefile.am: Reformat. * mp11/node1/Makefile.am: Remove all-local: $(ARCH). * mp11/node2/Makefile.am: Remove all-local: $(ARCH). * mp12/Makefile.am: Reformat. * mp12/node1/Makefile.am: Remove all-local: $(ARCH). * mp12/node2/Makefile.am: Remove all-local: $(ARCH). * mp13/Makefile.am: Reformat. * mp13/node1/Makefile.am: Remove all-local: $(ARCH). * mp13/node2/Makefile.am: Remove all-local: $(ARCH). * mp14/Makefile.am: Reformat. * mp14/node1/Makefile.am: Remove all-local: $(ARCH). * mp14/node2/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. mp01/Makefile.am: Reflect having moved automake. mp01/node1/Makefile.am: Reflect having moved automake. mp01/node2/Makefile.am: Reflect having moved automake. mp02/Makefile.am: Reflect having moved automake. mp02/node1/Makefile.am: Reflect having moved automake. mp02/node2/Makefile.am: Reflect having moved automake. mp03/Makefile.am: Reflect having moved automake. mp03/node1/Makefile.am: Reflect having moved automake. mp03/node2/Makefile.am: Reflect having moved automake. mp04/Makefile.am: Reflect having moved automake. mp04/node1/Makefile.am: Reflect having moved automake. mp04/node2/Makefile.am: Reflect having moved automake. mp05/Makefile.am: Reflect having moved automake. mp05/node1/Makefile.am: Reflect having moved automake. mp05/node2/Makefile.am: Reflect having moved automake. mp06/Makefile.am: Reflect having moved automake. mp06/node1/Makefile.am: Reflect having moved automake. mp06/node2/Makefile.am: Reflect having moved automake. mp07/Makefile.am: Reflect having moved automake. mp07/node1/Makefile.am: Reflect having moved automake. mp07/node2/Makefile.am: Reflect having moved automake. mp08/Makefile.am: Reflect having moved automake. mp08/node1/Makefile.am: Reflect having moved automake. mp08/node2/Makefile.am: Reflect having moved automake. mp09/Makefile.am: Reflect having moved automake. mp09/node1/Makefile.am: Reflect having moved automake. mp09/node2/Makefile.am: Reflect having moved automake. mp10/Makefile.am: Reflect having moved automake. mp10/node1/Makefile.am: Reflect having moved automake. mp10/node2/Makefile.am: Reflect having moved automake. mp11/Makefile.am: Reflect having moved automake. mp11/node1/Makefile.am: Reflect having moved automake. mp11/node2/Makefile.am: Reflect having moved automake. mp12/Makefile.am: Reflect having moved automake. mp12/node1/Makefile.am: Reflect having moved automake. mp12/node2/Makefile.am: Reflect having moved automake. mp13/Makefile.am: Reflect having moved automake. mp13/node1/Makefile.am: Reflect having moved automake. mp13/node2/Makefile.am: Reflect having moved automake. mp14/Makefile.am: Reflect having moved automake. mp14/node1/Makefile.am: Reflect having moved automake. mp14/node2/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+3
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-7/+0
| | | | | | | | | which does minor cleanup for Makefile.ams below mptests, which only removes some bogus comments from the Makefile.ams. To apply: patch -p1 < rtems-rc-19991203-8.diff ./bootstrap
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-241-0/+58
