Updates #3053.
Update #3753.
Update #3818.
Update #3382
Update #2843.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
of this patch set.
