Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* tztest/init.c: Build when using buffered test IO.
* tztest/init.c: Call tzset() even though it may be called for us
implicitly along the way.
* Makefile.am, configure.ac: Added timezone test.
* tztest/Makefile.am, tztest/init.c, tztest/tztest.doc,
tztest/tztest.scn: New files.
