These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
Update #3818.
* devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c,
malloctest/init.c, termios03/termios_testdriver_polled.c,
termios04/termios_testdriver_intr.c: Remove warnings.
* termios04/termios_testdriver_intr.c: Task driven IO now works.
* Makefile.am, configure.ac: Add new test to exercise termios RX and TX
interrupt driven IO support.
* termios04/.cvsignore, termios04/Makefile.am, termios04/init.c,
termios04/termios04.doc, termios04/termios04.scn,
termios04/termios_testdriver_intr.c,
termios04/termios_testdriver_intr.h: New files.
