Updates #3053.
Updates #3053.
Do not generate the test tar archive on the host computer since not all
file systems support symbolic links.
Close #3968.
Update #3753.
Use uniform pattern for all TAR file names. Use the dl* tests as a
template.
Update #3818.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
See also:
https://www.gnu.org/software/automake/manual/html_node/Built-Sources-Example.html
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* devfs04/Makefile.am, deviceio01/Makefile.am,
monitor02/Makefile.am, stackchk01/Makefile.am,
tar02/Makefile.am, termios01/Makefile.am,
tztest/Makefile.am: Add missing files.
PR 1654/testing
* deviceio01/init.c, deviceio01/deviceio01.doc,
deviceio01/deviceio01.scn, deviceio01/test_driver.c,
deviceio01/test_driver.h, deviceio01/Makefile.am: New test added.
* Makefile.am, configure.ac: Changes to added above test.
* tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
* tar01/Makefile.am, tar02/Makefile.am: Apply clean-local to remove
intital_fs directory.
* tar01/Makefile.am, tar02/Makefile.am: Apply TARTESTS.
* tar01/Makefile.am:
Apply $LN_S, $PAX. Use subshell for tarball creation.
Don't add initial_fs to CLEANFILES.
* tar02/Makefile.am:
Eliminate stamp-filesystem.
Add BUILT_SOURCES.
* configure.ac: autoconf >= 2.65, automake >= 1.11.
* tar01/Makefile.am, tar02/Makefile.am: Fix dependencies for parallel
build.
* tar01/Makefile.am, tar02/Makefile.am: Replace mkdir cascade
with $(MKDIR_P).
* tar01/Makefile.am, tar02/Makefile.am: Misc. fixes.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
