* | cpukit: Prevent error with disabled stack checker | Kinsey Moore | 2022-01-27 | 1 | -0/+7 |
When the stack checker is not enabled, the stack checker reporting function can still be called. This prevents that call from performing a null memory access in trying to find the high water mark if the stack checker was never initialized. This also introduces a test to ensure this call does not cause a crash. Closes #4588 |
