Updates #3053.
* malloctest/task1.c, stackchk/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* cpuuse/task1.c, cpuuse/tswitch.c, malloctest/task1.c,
stackchk/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c,
cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c,
malloctest/system.h, malloctest/task1.c, monitor/init.c,
monitor/system.h, putenvtest/init.c, rtems++/Init.cc,
rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c,
stackchk/blow.c, stackchk/init.c, stackchk/system.h,
stackchk/task1.c: URL for license changed.
like signal dispatching.
