brains GmbH.
In case the Newlib _REENT_THREAD_LOCAL configuration option is enabled, the
struct _reent is not defined (there is only a forward declaration in
<sys/reent.h>). Instead, the usual members of struct _reent are available as
dedicatd thread-local storage objects.
Update #4560.
Check that the state of rand() and lrand48() is thread-specific,
that they are properly initialized, and return the expected
sequence of pseudo-random numbers for default seed values.
Updates #3053.
Added tests for exit procedures to ensure proper resource
cleanup. The test now checks cleanup for files assigned
to stdio streams and non-stdio streams.
Updates #4625.
Edit assert statements in worker thread to check initialization against the
__cleanup member of struct _reent instead of __sdidinit. This will allow the
removal of sdidinit in a follow up Newlib patch.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3870
Update #3753.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
With global stdio streams, a freopen() would close the global stream
object.
Update #3012.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
