* | testsuites/libtests/[d-o]*: Change license to BSD-2 | Joel Sherrill | 2022-04-07 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-09-29 | 1 | -0/+4 |
| | | | | | * mouse01/init.c, mouse01/msmouse.c, mouse01/serial_mouse_config.c: Add HAVE_CONFIG_H. | ||||
* | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-14 | 1 | -0/+35 |
* Makefile.am, configure.ac: Add test for Mouse Parser Engine (Microsoft Mouse paths) and Serial Mouse Driver. * mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c, mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c, mouse01/serial_mouse_config.c: New files. |
