Updates #3053.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3818.
Update #3382
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Avoid unnecessary use of CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM.
of this patch set.
This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f.
This reverts commit 6a5bd1c65c005457455db344f2ee831d7a5cf99b.
Use C pre-processor instead of shell commands.
for details.
* math/init.c, mathf/init.c, mathl/init.c: Move configuration section.
* math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate.
* math/domath.in: Generate domath* prototype.
* math/init.c, mathf/init.c, mathl/init.c: Now run.
* math/math.scn, mathf/mathf.scn, mathl/mathl.scn: Regenerate.
