brains GmbH.
Updates #3053.
Updates #3053.
Updates #4625.
A device tree blob must be aligned on an 8-byte boundary.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This allows BSPs to use this library.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
