brains GmbH.
Updates #3053.
Updates #4625.
This adds the possibility to open an I2C bus with O_NONBLOCK (or set it
later via fcntl) to get non-blocking transmissions. This means that if
the bus is busy, a read, write or transfer ioctl will return with a
EAGAIN errno.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This I2C driver framework has some major differences compared to libi2c.
* It is compatible to the Linux I2C user-space API.
* It uses generic IMFS nodes and thus reduces the levels of indirection.
* The drivers don't have to mess around with minor numbers to get their
state information.
* No arbitrary bus controller model is assumed. The main task of an I2C
bus controller driver is to process I2C messages. How this is done is
private to the driver.
* Scatter/gather operations are supported (I2C_M_NOSTART).
