Update #3850
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Update #3753.
There is no need to keep the password throughout the session.
Update #3530.
This configuration is superfluous in these tests.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
It is invalid to issue a SIZE command once a data transfer is
in progress. For reads we issue the SIZE command before the RETR
command and get a snapshot of the file size. For writes the file size
is initialized to zero and incremented for each write chunk.
* ftp01/init.c: Account for extra FTP worker task stack sizes.
* ftp01/.cvsignore, ftp01/Makefile.am, ftp01/ftp01.doc,
ftp01/ftp01.scn, ftp01/init.c: New files.
* Makefile.am, configure.ac: Reflect changes above.
