path: root/testsuites/libtests/dl09/dl09-o3.c (follow)
* tests: Add header for RTEMS test printerSebastian Huber2023-09-261-1/+1
| | | | | | | | | | The <rtems/test-info.h> header file is required for every RTEMS test program. Move the RTEMS test printer support to a dedicated header file <rtems/test-printer.h>. This removes an unnecessary dependency to the RTEMS printer support in <rtems/test-info.h>. Tests using the RTEMS Testing Framework no longer depend on the <rtems/printer.h>.
* testsuites/libtests/dl*: Change license to BSD-2Joel Sherrill2022-04-071-3/+22
| | | | Updates #3053.
* libtest: <rtems/test.h> to <rtems/test-info.h>Sebastian Huber2020-07-231-1/+1
| | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199.
* libtests/dl*: Rename source filesSebastian Huber2019-11-261-0/+41
Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use *.cc for C++ source files instead of *.cpp to be in line with other C++ source files. Update #3818.
