The <rtems/test-info.h> header file is required for every RTEMS test
program. Move the RTEMS test printer support to a dedicated header file
<rtems/test-printer.h>. This removes an unnecessary dependency to the
RTEMS printer support in <rtems/test-info.h>.
Tests using the RTEMS Testing Framework no longer depend on the
<rtems/printer.h>.
Updates #4682
Updates #3053.
Updates #3053.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use
*.cc for C++ source files instead of *.cpp to be in line with other C++
source files.
Update #3818.
Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the
memory demands of the tests.
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
Updates #3686
Tracking references lets us manage when an object file can be
unloaded. If an object file has references to it, it cannot be
unloaded.
Modules that depend on each other cannot be unloaded.
Updates #3605
Using CONFIGURE_MINIMUM_TASK_STACK_SIZE increases also the interrupt
stack size. This is an issue on some BSPs. Use
CONFIGURE_INIT_TASK_TABLE_SIZE instead.
Update #3433.
Update #3382
The link time wrap of printf leads to unresolved symbols in the loadable
modules. This resulted in infinite loops and test timeouts. Use
rtems_printf() for output.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
See also:
https://www.gnu.org/software/automake/manual/html_node/Built-Sources-Example.html
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
This has been tested on SPARC, i386, PowerPC and ARM.
Closes #2767.
Loads 2 interdependent ELF object files.
