brains GmbH.
Updates #3053.
Updates #3053.
Updates #4625.
There were not a lot of these and they did not match the patterns
of the C.
Updates #4625.
Update #3753.
Close #3358.
Update #3358.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Add block_count and media_blocks_per_block to rtems_disk_device. Add
and use rtems_disk_init_phys() and rtems_disk_init_log().
This allows addtion of per disk statistics for example.
The task stack size for the swap-out and worker tasks is now
configurable. The bdbuf task resources are now included in the work
space size estimate.
for details.
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block09/init.c,
block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
block05/init.c, block07/init.c, bspcmdline01/init.c,
stringto01/init.c, stringto01/stringto_test_template.h,
termios01/init.c, termios01/termios_testdriver.c, termios02/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
corrections in block tests
added Makefile.am
* block01/.cvsignore: New file.
