* | Remove (Abandoned) | Ralf Corsepius | 2010-06-17 | 1 | -34/+0 |
* | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-11 | 1 | -1/+1 |
| | | | | | | | | | * itronmbf01/init.c, itronmbf01/itronmbf01.scn, itrontask02/init.c, itrontask03/itrontask03.scn, itrontask03/task1.c, itrontask04/itrontask04.scn, itrontask04/task3.c: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis. | ||||
* | 2006-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-17 | 1 | -3/+2 |
| | | | | | | * itrontask04/init.c, itrontask04/itrontask04.scn: Cannot print with dispatching disabled so fix test not to print while dispatching is disabled. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 1 | -2/+2 |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 1 | -0/+35 |
