* | Remove (Abandoned) | Ralf Corsepius | 2010-06-17 | 1 | -39/+0 |
* | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-20 | 1 | -1/+1 |
| | | | | * configure.ac: Don't add -ansi -fasm to CFLAGS. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -1/+1 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -3/+0 |
| | | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 1 | -1/+1 |
| | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -2/+2 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-10 | 1 | -1/+1 |
| | | | | * configure.ac: Reflect having moved to testsuites/. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 1 | -1/+0 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-02 | 1 | -1/+0 |
| | | | | * configure.ac:Remove RTEMS_CHECK_CPU. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -1/+1 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-27 | 1 | -2/+0 |
| | | | | | * configure.ac: Remove CC_CFLAGS_DEBUG_V. CC_CFLAGS_DEFAULT (obsolete). | ||||
| | | | | | * configure.ac: Remove CC_CFLAGS_PROFILE_V. Remove CC_LDFLAGS_PROFILE_V. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -1/+0 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -1/+1 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-16 | 1 | -2/+0 |
| | | | | * configure.ac: Remove ENABLE_GCC28. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+51 |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. |
