The <rtems/test-info.h> header file is required for every RTEMS test
program. Move the RTEMS test printer support to a dedicated header file
<rtems/test-printer.h>. This removes an unnecessary dependency to the
RTEMS printer support in <rtems/test-info.h>.
Tests using the RTEMS Testing Framework no longer depend on the
<rtems/printer.h>.
brains GmbH.
Updates #4662
The test uses snprintf().
Update #4666.
Update #4666.
Update #4666.
