brains GmbH.
Updates #3053.
Updates #4625.
The addition of the entire *utime*() family of functions resulted
in this call returning ENOENT not ENXIO. This is better aligned
with the POSIX definition of the methods.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
of this patch set.
Update #2408.
The scope of the file system operations is the file system instance.
The scope of the file system node handlers is the file location. The
benefit of moving the operations to the mount table entry is a size
reduction of the file location (rtems_filesystem_location_info_t). The
code size is slightly increased due to additional load instructions.
Restructure rtems_filesystem_mount_table_entry_t to improve cache
efficiency.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
