* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | testsuites/fstests/*: Change license to BSD-2 | Joel Sherrill | 2022-04-07 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | testsuite/fstests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -29/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | fsjffs2gc01: Fix sporadic test failures | Sebastian Huber | 2017-11-06 | 1 | -0/+8 |
* | JFFS2: RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION | Sebastian Huber | 2016-12-20 | 1 | -1/+5 |
| | | | | Update #2844. | ||||
* | JFFS2: Add RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION | Sebastian Huber | 2016-12-20 | 1 | -0/+57 |
| | | | | | | Add IO control to force a garbage collection. Update #2844. | ||||
* | JFFS2: Add RTEMS_JFFS2_GET_INFO | Sebastian Huber | 2016-12-20 | 4 | -0/+297 |
Add IO control RTEMS_JFFS2_GET_INFO to get some JFFS2 filesystem instance information. Update #2844. |
