brains GmbH.
Updates #3053.
Updates #4625.
Adds a peek function that allows (for example) a file system to suggest
the next blocks that should be used for read ahead. This can increase
the read speed of fragmented files.
Update #3689
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3753.
Update #3358.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Update #2622.
Separate cluster write from sector write for quick file write.
New test fstests/fsdosfswrite01.
