* | testsuites/ada/tmtests/tm2*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | ada: Introduce RTEMS.Size type | Sebastian Huber | 2018-01-29 | 1 | -1/+1 |
| | | | | | | | Some time ago the Classic API object size related parameters were changed to use size_t. Reflect this in the Ada bindings. Update #3082. | ||||
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 1 | -2/+2 |
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 1 | -0/+252 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
