* | testsuites/ada/sptests/sp1*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 4 | -15/+108 |
| | | | | Updates #3053. | ||||
* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 1 | -19/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | ada/sp19: Add m4 generated sptest.adb | Sebastian Huber | 2019-11-29 | 2 | -0/+2996 |
| | | | | Update #3818. | ||||
* | testsuites/ada: Introduce init.c files | Sebastian Huber | 2019-11-27 | 2 | -2/+2 |
| | | | | | | | Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818. | ||||
* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 1 | -1/+0 |
* | ada/sp19: Add missing FP attribute | Sebastian Huber | 2017-12-02 | 1 | -2/+2 |
* | ada: Add standard test begin/end message | Sebastian Huber | 2017-12-01 | 2 | -2/+4 |
* | ada: Delete superfluous CONFIGURE_SPTEST | Sebastian Huber | 2017-12-01 | 1 | -2/+0 |
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 7 | -0/+695 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
