path: root/testsuites/ada/sptests/sp04/config.h (follow)
* testsuites/ada: Introduce init.c filesSebastian Huber2019-11-271-33/+0
| | | | | | | Provide an init.c for each Ada test instead of the #include <config.h> magic which works only due to hand crafted include paths. Update #3818.
* ada: Add standard test begin/end messageSebastian Huber2017-12-011-0/+2
* ada: Delete superfluous CONFIGURE_SPTESTSebastian Huber2017-12-011-2/+0
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* ada-tests: Move to testsuites/adaSebastian Huber2017-10-121-0/+33
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079.
