* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 1 | -18/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | build: Remove local.am | Sebastian Huber | 2018-10-10 | 1 | -1/+0 |
* | build: Remove EXTRA_DIST | Sebastian Huber | 2018-04-04 | 1 | -2/+0 |
| | | | | | A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am. | ||||
* | ada-tests: Move to testsuites/ada | Sebastian Huber | 2017-10-12 | 1 | -0/+21 |
This solves a build dependency issue, e.g. building tests before librtemsbsp.a exists. Close #3079. |
